Connecting Two saperated Sites
Discussion in '3CX Phone System - General' started by engnusef, Aug 11, 2009.
  1. engnusef
    Aug 11, 2009
    Dears in 3cx forum,
    I have two geographically separated sites... (Primary and secondary) and an internet connection of 1 Mbps is available on both sides. Now, I want to link all users in both sides by using 3cx VOIP system. Notice: 4 PSTN lines are available on primary site only.
    And by the ways the Cisco 875W routers are used in both sides. ( see the attached topology)
    Now my question is ... linking those sites are possible using 3cx? If yes which version can I use?
    Final notice: number if users in primary site are 20 and number of users in secondary site are 6
    With most regards
    Abdullah
  2. discovery1
    discovery1 Member
    Aug 4, 2008
    355
    You can link them by having a 3CX system (commercial version) in each office and using the bridging feature but the extension numbers in each office will be different. Also with separate 3CX systems they behave as separate entities in terms of phone books and call queues/ring groups.
    Alternatively you can have a single 3CX system at the main office and have the second site with the 6 handsets each register against the 3CX in the main office.
