Connection is distorted
Discussion in 'Windows' started by Joepie, Sep 16, 2010.
  1. Joepie
    Aug 30, 2010
    14
    When phoning, the connected called person's goes on and off for sometimes a few seconds, for sometimes a longer period. What could be the case?
    (Until a few days ago 3CX Phone functioned quite well) Did not do anything peculiar at the time.
  2. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,526
    71
    What it means "goes off"? Audio missing, video missing or both?
  3. leejor
    11,073
    323
    Is this going through the 3CX PBX or directly to a VoIP provider? If through 3CX, are other extensions experiencing the same problems? If directly to a VoIP provider, have you tried using the PC at a different location (high speed connection)?
