Connection issue on 3Cx assistant v9
Discussion in '3CX Phone System - General' started by tratta, Jul 1, 2011.
  1. tratta
    Jun 30, 2011
    I cant connect from 3 cx assistant. I tried local/remote with pin and password but no sucess
    Just a message "Logging in" on status bar
    3Cx server v10 patch 1
    3cx assistant v9
    windows 7
    My log:
    110701-103705.213:001:X: -- TabList -----
    110701-103705.213:001:X: [CfgProfile_P001] 0 5055 wljeUHcw8EWsu6OkGflFqg
    110701-103711.344:00E:I: OnStateChanged: CID wljeUHcw8EWsu6OkGflFqg Connecting -> Disconecting
    110701-103711.344:00E:I: OnStateChanged: CID wljeUHcw8EWsu6OkGflFqg Disconecting -> SessionTimeout
    110701-103711.359:00E:I: OnTerminate: CID wljeUHcw8EWsu6OkGflFqg
    110701-103711.359:00E:I: Session wljeUHcw8EWsu6OkGflFqg removed from collection
    110701-103711.359:00E:I: OnStateChanged: CID bTFv9j41IkmF4swPDK7vYA Undefined -> Connecting
    110701-103711.375:001:I: Server disconnected, session name=CfgProfile_P001wljeUHcw8EWsu6OkGflFqg
    110701-103711.375:00E:X: . . adding request bTFv9j41IkmF4swPDK7vYA : SUBSCRIBE 1
    110701-103711.390:00E:I: - Bad Packets skiped =0
    110701-103711.390:00E:I: - Session count=1
    110701-103711.390:00E:I: - 8153@192.168.1.41:AssistClient_9.0.15770.0 5486 bTFv9j41IkmF4swPDK7vYA Connecting TrueFalseFalse
    110701-103711.390:00E:I: (RE)SEND:CID:bTFv9j41IkmF4swPDK7vYA,CSEQ:1,REQ:SUBSCRIBE,TO:sip:8153@192.168.1.41:5486, resends=0
    110701-103711.406:00E:I: - UDP sent 431 bytes to 192.168.1.41:5486 : 431
    110701-103711.406:00E:X: SendQueue[192.168.1.41:5486] - pakets sent: 1 , bytes 431 *****
    110701-103713.403:00E:I: (RE)SEND:CID:bTFv9j41IkmF4swPDK7vYA,CSEQ:1,REQ:SUBSCRIBE,TO:sip:8153@192.168.1.41:5486, resends=1
    110701-103713.418:00E:I: - UDP sent 431 bytes to 192.168.1.41:5486 : 431
    110701-103713.418:00E:X: SendQueue[192.168.1.41:5486] - pakets sent: 1 , bytes 431 *****
    110701-103717.412:00E:I: (RE)SEND:CID:bTFv9j41IkmF4swPDK7vYA,CSEQ:1,REQ:SUBSCRIBE,TO:sip:8153@192.168.1.41:5486, resends=2
    110701-103717.428:00E:I: - UDP sent 431 bytes to 192.168.1.41:5486 : 431
    110701-103717.428:00E:X: SendQueue[192.168.1.41:5486] - pakets sent: 1 , bytes 431 *****
    110701-103720.501:001:X: -- TabList -----
    110701-103720.501:001:X: [CfgProfile_P001] 0 5055 bTFv9j41IkmF4swPDK7vYA
    110701-103725.415:00E:I: (RE)SEND:CID:bTFv9j41IkmF4swPDK7vYA,CSEQ:1,REQ:SUBSCRIBE,TO:sip:8153@192.168.1.41:5486, resends=3
    110701-103725.430:00E:I: - UDP sent 431 bytes to 192.168.1.41:5486 : 431
    110701-103725.430:00E:X: SendQueue[192.168.1.41:5486] - pakets sent: 1 , bytes 431 *****
    110701-103726.398:00E:I: - Bad Packets skiped =0
    110701-103726.398:00E:I: - Session count=1
    110701-103726.398:00E:I: - 8153@192.168.1.41:AssistClient_9.0.15770.0 5486 bTFv9j41IkmF4swPDK7vYA Connecting TrueFalseFalse
    110701-103735.851:001:X: -- TabList -----
    110701-103735.851:001:X: [CfgProfile_P001] 0 5055 bTFv9j41IkmF4swPDK7vYA
    110701-103741.405:00E:I: - Bad Packets skiped =0
    110701-103741.405:00E:I: - Session count=1
    110701-103741.405:00E:I: - 8153@192.168.1.41:AssistClient_9.0.15770.0 5486 bTFv9j41IkmF4swPDK7vYA Connecting TrueFalseFalse
    110701-103741.420:00E:I: (RE)SEND:CID:bTFv9j41IkmF4swPDK7vYA,CSEQ:1,REQ:SUBSCRIBE,TO:sip:8153@192.168.1.41:5486, resends=4
    110701-103741.436:00E:I: - UDP sent 431 bytes to 192.168.1.41:5486 : 431
    110701-103741.436:00E:X: SendQueue[192.168.1.41:5486] - pakets sent: 1 , bytes 431 *****
    110701-103751.248:001:X: -- TabList -----
    110701-103751.248:001:X: [CfgProfile_P001] 0 5055 bTFv9j41IkmF4swPDK7vYA
    110701-103756.412:00E:I: - Bad Packets skiped =0
    110701-103756.412:00E:I: - Session count=1
    110701-103756.412:00E:I: - 8153@192.168.1.41:AssistClient_9.0.15770.0 5486 bTFv9j41IkmF4swPDK7vYA Connecting TrueFalseFalse
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    3CX Assistant doesn't work with V10 at all, you need to use MyPhone.
    Thanks,
    Nate
  3. tratta
    Jun 30, 2011
    I need integration to Dynamics CRM 2011.
    The mainly reason for I buy 3Cx is the crm integration.
    So I need to downgrade to v9 server?
  4. nbailey
    nbailey Member
    Jan 31, 2011
    359
    CRM integration will be available shortly for V10. If you need it right now and can't wait then yes you need to downgrade.
    If you can wait a few weeks then I would hold out.
    Thanks,
    Nate
  5. tratta
    Jun 30, 2011
    Thank you
    Do you have the an approximately date for this release?
  6. nbailey
    nbailey Member
    Jan 31, 2011
    359
    Not normally but all I can say is soon. I will say this, if you can't wait 30 days or so then switch.
    Thanks,
    Nate
