Connection settings desktop Vs Android ?
Discussion in 'Android' started by Gaucho, Jul 1, 2010.
  1. Gaucho
    Mar 29, 2010
    The connections settings on the 3CX softphone using sip are pretty straigth forward to set-up. Why aren't you using the same credentials for the android ?
    On the desktop you have to fill Extension : (which is my phone number)
    ID : (which is an authorization number from my sip provider)
    Password : XXXX
    I don't see the same credentials on the android and I don't know where to enter my authorization user number. Can someone help me with that ?
