Connection Timeout
Discussion in 'Windows' started by pauljoseph, Feb 28, 2011.
  1. pauljoseph
    Feb 28, 2011
    to anyone's knowledge, is there a timeout on a connection to a 3cx softphone (windows) of approximately THREE HOURS?
    many thanks
  2. abc123
    abc123 Active Member
    Nov 9, 2009
    712
    you asked this question in the other forum too.
    The same question gets you the same answer.
