Connection to 3CX API
Discussion in '3CX Phone System - General' started by Maciej Cygan, Jan 25, 2017.
  1. Maciej Cygan
    Jan 19, 2017
    12
    Hello everyone,
    I seek some advice. I am trying to initiate connection to 3CX call api with Java but i am having difficultly getting anywhere. Does any one know how the actual connection is made with .NET application so i can replicate this with java?
    When i try to telnet to port 5485 (from localhost - where 3cx is installed) the second i enter anything i get 'Connection closed by foreign host.' So i guess its not possible to login directly (or am i wrong ?). Also is there any documentation on how the actual API works ?
    Also the 3cxpscomcpp2.dll which supposed to be located in C:\Windows\Microsoft.NET\assembly\GAC_64 is missing
    PS. I know that java API for 3CX does not exist.
  2. Maciej Cygan
    Jan 19, 2017
    12
    After some fiddling around i wonder. Is it possible to actually get active connection going with application other then .NET ? Anyone?
  3. GiannosC_3CX
    GiannosC_3CX Guest
  4. Maciej Cygan
    Jan 19, 2017
    12
    Ah wrong section then :) Thank you
