Connection to 3CX API
Discussion in 'CRM / Helpdesk / App Integration' started by Maciej Cygan, Jan 30, 2017.
  1. Maciej Cygan
    Jan 19, 2017
    12
    Hello everyone,
    I seek some advice. I am trying to initiate connection to 3CX call api with Java but i am having difficultly getting anywhere. Does any one know how the actual connection is made with .NET application so i can replicate this with java?
    When i try to telnet to port 5485 (from localhost - where 3cx is installed) the second i enter anything i get 'Connection closed by foreign host.' So i guess its not possible to login directly (or am i wrong ?). Also is there any documentation on how the actual API works ? I have seen the 'ObjectModel v14,v15 and Samples but not much documentation there.
    Also the 3cxpscomcpp2.dll which supposed to be located in C:\Windows\Microsoft.NET\assembly\GAC_64 is missing
    PS. I know that java API for 3CX does not exist, but i do hope that I can create something that will at least resemble java api for 3cx.
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,453
    115
    Hi there,
    It's not possible to access from java. You can create a proxy in .net, which access the API from .net and then connects to your java program via sockets for example.
    The DLL you're looking for is in the 3CX installation directory.
    Kind regards.
  3. Maciej Cygan
    Jan 19, 2017
    12
    Hello Ernesto,
    Thank you for the answer. This slightly complicates things... Do you know if 3CX will release the API so it will allow connection and control through TCP ?
    Thanks,
    Maciej
    Bradley Haylock likes this.
  4. edossantos
    Jun 27, 2007
    1,453
    115
    I don't think so, at least in the short term...
