Connection to CallCentric failing
Discussion in '3CX Phone System - General' started by joshuao3, May 22, 2016.
  1. joshuao3
    Jan 11, 2013
    20
    According to 3CX my trunks with CallCentric are registered. According to CallCentric the 3CX server is not registered. This just started happening in the last 24 hours. I see this in the log within 3CX:
    22-May-2016 11:24:44.919 Exception: ParseException ParseBuffer.cxx:102, Parse failed Expected "
    " in context: Contents
    Messages-Waiting: no
    Message-Account: sip:17772773385@callcentric.com
    Voice-Message: 0/0 (0/0)
    Fax-Message: 0/0 (0/0)
    None: 0/0 (0/0)
    @ ParseBuffer.cxx:102
    Does anybody have any idea as to what could be going on?
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,342
    535
    I am going through my logs and i am seeing the exact same error in my PBX at the exact date but not any more. I suspect this had something to do with Callcentric. However i was able to make and receive calls at the specific date.
    My callcentric also showed registered. Were you able to make/receive calls?
    I no longer see this error though. Are you still experiencing issues?
