connection with GXW4104
Discussion in 'Windows' started by aghiadb, Apr 3, 2008.
  1. aghiadb
    Apr 3, 2008
    Dears
    i setup my system to use phone over wifi, now i can communcate with internal extention,
    but when i dial any external nomber, i still can hear the tone, and the timer is running, and i get this msg from the status screens
    06:55:08.031 StratLink::eek:nHangUp [CM104001] Call(11): Ext.103 hung up call; cause: BYE; from IP:192.168.1.250
    06:54:46.625 CallLegImpl::eek:nConnected [CM103001] Call(11): Created audio channel for Ln:10000@third (192.168.1.160:5012) with third party (192.168.1.250:9000)
    06:54:46.625 StratInOut::eek:nConnected [CM104005] Call(11): Setup completed for call from Ext.103 to Ln:10000@third
    06:54:46.625 CallLegImpl::eek:nConnected [CM103001] Call(11): Created audio channel for Ext.103 (192.168.1.250:9000) with third party (192.168.1.160:5012)
    06:54:46.609 CallConf::eek:nProvisional [CM103003] Call(11): Ln:10000@third is ringing
    06:54:46.515 CallConf::eek:nIncoming [CM103002] Call(11): Incoming call from 103 (Ext.103) to sip:043664596@192.168.1.254
    07:00:09.718 StratLink::eek:nHangUp [CM104001] Call(12): Ext.102 hung up call; cause: BYE; from IP:192.168.1.249
    06:59:52.781 CallLegImpl::eek:nConnected [CM103001] Call(12): Created audio channel for Ln:10000@third (192.168.1.160:5016) with third party (192.168.1.249:9000)
    06:59:52.781 StratInOut::eek:nConnected [CM104005] Call(12): Setup completed for call from Ext.102 to Ln:10000@third
    06:59:52.781 CallLegImpl::eek:nConnected [CM103001] Call(12): Created audio channel for Ext.102 (192.168.1.249:9000) with third party (192.168.1.160:5016)
    06:59:52.781 CallConf::eek:nProvisional [CM103003] Call(12): Ln:10000@third is ringing
    06:59:52.671 CallConf::eek:nIncoming [CM103002] Call(12): Incoming call from 102 (Ext.102) to sip:0505704324@192.168.1.254
    these are two trials, can any help .
  2. eugeneboo
    Apr 4, 2008
    have you tried using the 3CX VoIP Client for an external number? If Yes, is it working or just the same?
    Is the extension number that you dialed ringing?
    Is the GXW4104 registered on the 3CX Phone System?
    Try check or uncheck the Wait for Dial Tone in your GXW4104.
  3. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    Could you please upgrade your system to version 5.1?
    I'm expecting it will resolve a lot of issues.
  4. aghiadb
    Apr 3, 2008
    Dear
    thanx for help
    actually, it was something in the configuration of the gateway, as the extension ID was wrong.
    regards.
