Constant ringing, HT-503 not passing cell phone call to 3CX
Discussion in '3CX Phone System - General' started by mutti_wilson, Aug 29, 2008.
  1. mutti_wilson
    May 2, 2008
    53
    I am having the same problem i was with the SPA-3102 of no calls from a certain phone (2 phone on the verizon network so far) that ring endlessly. Nothing shows up in the 3cx log and I don't see a log or anything in the HT-503's management. Why can't stuff just work?
  2. mutti_wilson
    May 2, 2008
    53
    I have the exact same phone (Motorola Q) as one which does not work and it works perfect. I'm going to try to update the other phone and see if that helps.
  3. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    I did not found enough help for ht503
    Check this posts and may be you help me back
    http://www.3cx.com/forums/ht503-help-4691.html?highlight=ht503
    http://www.3cx.com/forums/request-for-ht503-firmware-4718.html?highlight=ht503
    http://www.3cx.com/forums/3cx-not-work-with-gateway-fxo-4733.html?highlight=ht503
  4. mutti_wilson
    May 2, 2008
    53
    Updated the phone to no avail. I must just be cursed?
