Contact import (Greek)
Discussion in 'Windows' started by gvsoft, Nov 3, 2016.
  1. gvsoft
    Nov 2, 2016
    31
    I am having trouble importing greek csv contact lists. When I import them I see nothing but question marks and Chinese.
    Does anyone know what I need to do to the csv file before I import it in the 3cx?
  2. XanthiZ
    3CX Support
    Dec 18, 2015
    46
    7
    Hello
    Can you make sure the CSV File you are using the encoding is UTF-8?
    Can you provide us with the CSV file you are using ?
    When i uploaded the CSV File with Greek Contacts everything was shown correctly.
  3. gvsoft
    Nov 2, 2016
    31
    I found a solution using Google Spreadsheet, pasting my company contacts in there and then saving, downloading and importing the csv in the 3cx. Tried it and it works.
