Contacts details crossed with call reports
Discussion in 'Ideas' started by VictorSP, May 11, 2017.
  1. VictorSP
    Sep 6, 2016
    71
    13
    Could be a good idea if contact details added into Contacts will be crossed when regerate call reports and appears on them, just for example Name and Last Name, like for internal extensions shown Name, Last Name and (Extension or DDI).
    Bye!
  2. bosiogerman
    Mar 20, 2017
    5
    I need the same feature, thanks
