Contacts: Display of Name and Surname
Discussion in 'Windows' started by Peter2_1, Dec 15, 2016.
  1. Peter2_1
    Dec 15, 2016
    11
    I imported contacts from Outlook, and they are displayed as
    Given Name / Familyname:
    James Dean
    Marilyn Monroe
    Can it be changed to:
    Dean James
    Monroe Marilyn
  2. Peter2_1
    Dec 15, 2016
    11
  3. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @Peter2_1,
    You can try changing the display format from the Management Console > Contacts > Options
