Contacts in History shown as Unknown
Discussion in 'iOS' started by HugovanRhijn, Jul 3, 2013.
  1. HugovanRhijn
    Jul 3, 2013
    7
    I like 3CX for iPhone very much. But is there an explanation for the fact that if you have a contact with multiple phone numbers listed in your contacts data base, 3CX lists that contact - after having dialed one of these numbers - in history as "Unknown", while if there is only one number in the iOS contacts db available, it will display the name. Which is of course much easier to work with.
    Any explanation? Any solution?
  2. kevin
    kevin Member
    Nov 23, 2006
    316
    Hi there
    Could you specify exactly which version of 3CX Phone for iOS you are using?
  3. HugovanRhijn
    Jul 3, 2013
    7
    Hi Kevin
    I am using 1.1.5
  4. kevin
    kevin Member
    Nov 23, 2006
    316
    There are several variants of 3CX iOS software.
    Which one?
  5. HugovanRhijn
    Jul 3, 2013
    7
    Hi Kevin
    It is the first one - the VOIP/SIP Softphone app
    And fyi it's an iPhone5, running 6.1.4 (10B350)
  6. sbianco
    Jul 2, 2013
    8
    Hi there,
    We have attempted to replicate this and have not been successful.
    We have:
    1. Set up 2 numbers under one contact : Result- Shows the contact name
    2. Set up 2 names with the same number: Result- Shows the contact name of the first added contact
    Please advise as to whether or not we are missing something or are replicating in a different manner so we may adjust accordingly.
  7. HugovanRhijn
    Jul 3, 2013
    7
    Hi there
    Sorry for not having responded earlier.
    I just noticed something.
    I think the issue I noticed indeed has noting to do with what I thought earlier.
    Among all the "Unknown"s in the history log there was only one call with a name > screenshot 1.
    And then I remembered what had happened
    Yesterday I dialed a number only to find out that it was a number that I had put in my contacts db without paying notice to the fact that you have to record them with +32 country code plus area code instead of just the area code which I had done in this case. When I dialed the number (for Hugo Maes) and got no connection, I notice that the number is unusable so I went back to the contact db, changed and corrected the number and then dialed it. You see it appearing next in the history log and now under "Unknown".
    So I am now wondering whether the issue has anything to do with the integration settings > screenshot 2
  8. sbianco
    Jul 2, 2013
    8
    Hi there,
    The options within screenshot 2 should NOT effect the issue.
  9. HugovanRhijn
    Jul 3, 2013
    7
    Any other thoughts about where to look for a possible solution?
  10. Shoults
    Feb 7, 2011
    6
    Hi Hugo,
    I believe it would be best if you were to open a support ticket regarding this case so we can run the necessary testing and provide a clear and concise answer with our findings. Kindly also advise us of a step by step on what you are doing to replicate including the numbers you have saved and the method so our test would be as accurate as possible.
  11. HugovanRhijn
    Jul 3, 2013
    7
    Thanks for your response.
    If opening a support ticket would involve additional charges, it is currently no option for me.
    However, I can tell you that I have in the past two or three days noticed that while outgoing calls to numbers in my iPhone contacts database are registered as "Unknown", a call to my VOIP mailbox is registered under the name of my VOIP provider. And incoming calls are registered with the caller's number but not with his or her name even though that name is in the contacts db.
  12. sbianco
    Jul 2, 2013
    8
    Hi there,
    The only way in which we shall be able to provide you with a definitive answer to your query would be to test the scenario in further detail ourselves. As previously mentioned by Matthew, we DO require a support ticket in order to proceed with this issue.
  13. HugovanRhijn
    Jul 3, 2013
    7
    Thank you for your response.
    #1. I will continue to use the3CX iOS app. Because I like it and the quality of the communication I believe is better than other VOIP apps.
    #2. I thought I was doing you guys a favor, drawing your attention to what I thought was a bug in an excellent piece of software.
    #3 It a bug I am able to live with for the time being.
    #4. It is a free app. Therefor letting me pay for a support ticket is - in my opinion - not correct.
    #5. I continue to be willing to help you wherever I can.
    #6. I hope you'll be able to resolve the issue in the next update of the app.
    #7. Keep up the good work Guys (which underlines what I already mentioned under #1).
