Contacts information not saved
Discussion in 'iOS' started by DanielM, Apr 25, 2017.
  1. DanielM
    Mar 3, 2017
    9
    Hi guys,
    Since last update if I am trying to edit an existing contact the information remains unchanged, especially the mobile number.
    Also another issue that we encountered is that the name of the caller is not pulled from the database - used match exactly or match 10 or 9 numbers. Still not working.
    Anyone else having same issue?
  2. DanielM
    Mar 3, 2017
    9
    Can't edit/ delete/ remove a number from Phone field. Only adding/ edit another number in Mobile2 field is working correctly.
  3. Vali_3CX
    Vali_3CX Well-Known Member
    Dec 12, 2008
    1,502
    68
    Hi Daniel, thanks for feedback
    Daniel, for the second question (the Phone field) - which PBX version are you using? Please specify also the Service Pack number. I tried two PBX versions - on one happen, on the other one no, so I want to have a double check from you.
    For the first question (caller Id not pulled from database), sorry, I don't understand. Cand you describe what are you doing (make a call, have an incoming call, editing a contact...)
  4. DanielM
    Mar 3, 2017
    9
    Hi Vali and thank you for your answer.
    The 3CX iOS client version is 15.2.5.163 and the PBX version is 15.0.0 - I do not see any service pack number listed.
    For the first question - when a call is received the caller name is displayed in the first place, also displayed as missed call, but if I'm navigating to the Recents tab, there is only the number without the name.
    Thank you.
  5. Vali_3CX
    Dec 12, 2008
    1,502
    68
    OK, I will update this tomorrow (I'm not at work right now so I cannot check properly).
    However, I can confirm there is a bug with the Phone number, as you described, and it seems to be related with editing only - when I created a new contact all fields seems OK.
    Thanks again!
    DanielM likes this.
  6. Vali_3CX
    Dec 12, 2008
    1,502
    68
    Hi Daniel
    I've checked, we had these issues on our "to fix" list, but somehow we missed them (they are pretty old ones, honestly).
    Well, bottom line - we fixed them (15.2.6.176) so the next Beta and the official release should work OK.
    Thank you very much for spotting them!
    vali
  7. DanielM
    Mar 3, 2017
    9
    Thank you Vali !
  8. Vali_3CX
    Dec 12, 2008
    1,502
    68
    Hi Daniel
    We just uploaded today a new beta, so please try it via TestFlight to see if it's working properly,
    vali
