"ContactUri" usually, content of Contact field
Discussion in '3CX Phone System - General' started by Andy Schmidt, Apr 28, 2008.
  1. Andy Schmidt
    Andy Schmidt New Member
    Apr 3, 2008
    118
    when configuring a generic trunk, one of the "outbound parameter" options is the "Contact: Host" part.
    The DEFAULT value for the pull down is:
    When I place a call through that trunk, the provider receives the following contact header:
    Contact: <sip:myauthid@0.0.0.0>
    So, why is the "ContactUri" = 0.0.0.0? Where is that "Contact field" where it's taking that "0.0.0.0" from?
    When I change the drop down to OutHostPort - THEN it includes the correct external IP address of my 3CX server.
    (PS: The VOIP provider said it should NOT be 0.0.0.0: "This means that your system will never receive non-reply messages back from our proxy (such as BYE, or additional progress indication). This should be a valid IP address coming from your system.")
  2. Andy Schmidt
    Apr 3, 2008
    118
