Content of Sip Fields - Custom Values
Discussion in '3CX Phone System - General' started by alex22alex, Mar 24, 2010.
  1. alex22alex
    Jun 11, 2008
    38
    Hello All,
    I am trying to set a feild in the 'Content of Sip Fields ' ( Under Edit Voip Provider ) menu to a custom value. There is a column for this however it does not seem to be editable ?
    Any help would be great.
    Cheers Alex
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    You can edit this, select the field you want to create custom parameters for, in the "variable field" drop down box proceed to select custom parameter, a field called "custom parameters" will now appear on the right hand side of the "variable field" box.
  3. alex22alex
    Jun 11, 2008
    38
    Sorry. I have no idea how i missed this ! One of those days.
    Cheers Alex
  4. mfm
    mfm Active Member
    Mar 4, 2010
    641
    No worries we all have them :mrgreen:
