Convent Cisco 7940 SEP to SIP - Problem
Discussion in '3CX Phone System - General' started by Alliedbs, Jun 29, 2009.
  1. Alliedbs
    May 29, 2009
    19
    Hi All,
    Can anyone tell me how to convent the Cisco 7940 SEP to SIP. I have been trying for months but i can't convent to SIP. The TFTP server keep looking for SEP<< mac Address>> file. I try to put SIP and keep erro.
    Pls Advise.
    Thank you.
  2. newpool
    Mar 13, 2009
    11
    Have you got the SIP firmware on your TFTP server and executed a complete factory reset ? If you have it should work, I have all Cisco hardware (gateway & phones) on my 3CX system and have had no problems.
    This link tells you how to do it: http://www.voip-info.org/wiki/view/Cisco+7940+7960+Single+Step+Upgrade
    Good Luck!
  3. Discovery Technology
    Apr 19, 2008
    278
    Have you searched these forums as well?
    there are plenty of posts that provide a detailed run-through of how to do this - just remember, it's all in the timing of when you place the .bin files into the TFTP Server root directory...
  4. Alliedbs
    May 29, 2009
    19
    I have seen and try alot of time but the phone doesnt received the file for bin??? can anyone advise... thks for your help....
