Conversation allways stops after 32 sec
Discussion in '3CX Phone System - General' started by Zeljko, Sep 28, 2007.
  1. Zeljko
    Sep 25, 2007
    10
    I have an very strange problem with 3CX.
    Have allways hung up call after 32 seconds, internal and external calls.
    Is there anybody with similar problem?
    Here are server log:
    12:11:50.578 StratLink::eek:nHangUp [CM104001] Call(9): Ext.200 hung up call; cause: unknown
    12:11:18.312 CallLegImpl::eek:nConnected [CM103001] Call(9): Created audio channel for Ext.101 (192.168.178.37:33908) with third party (192.168.178.48:5004)
  2. Mirzab
    Mirzab Member
    Jul 22, 2007
    400
    I had a similar problem, lost a lot of sleep and hair trying many things. Eventually did a backup, un-installed, rebooted, clean install, restore - slept well :lol:
  3. livtrase
    Oct 8, 2007
    Same problem
    It seems like this problem is something that is seen regularly. I'm currently facing exactly the same issue with internal and external calls - on ATA-based and Voip hardphones. Hmmm - already tried to un-install and install everything as proposed here - did not work - any suggestions anyone? Thanks!
  4. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Try a different PC. Not the ideal solution but if you can test it out on another one it's pretty easy to transfer over.
    This way you can find out if it's the hardware (current PC), software (OS and/or 3CX issue), or even network/phone hardware.
