convert to IIS
Discussion in '3CX Phone System - General' started by mylove4life, Mar 27, 2012.
  1. mylove4life
    mylove4life New Member
    Jan 7, 2010
    165
    Hi all, is thier an easy way to convert the webserver to IIS?
  2. tom_ch
    Jul 6, 2011
    69
    I don't know if this works, but I'd try as following:
    - take a full 3CX Backup
    - Uninstall 3CX
    - Run Installer
    - Choose IIS
    - Restore 3CX Backup.
  3. mylove4life
    Jan 7, 2010
    165
    I'm not going to try someting if you have no idea if it works... why would you even post if you are sure if it will work.
  4. tom_ch
    Jul 6, 2011
    69
    Hey, calm down man!
    It just seemed logical to me, because the selection (in the installer) of the Webserver comes before the selection of "New installation vs. Restore Backup".
    I just wanted to bring in this idea.
    It would have been much worse, if I haven't written that I don't have tried it yet!!
  5. smokeman
    Dec 10, 2010
    50
    this did work for me. we had installed abyss thinking it would be lightweight, and work better. We were wrong, IIS handles the web traffic much better. We backed up, uninstalled, installed IIS, re-installed, and used the backup file.
    just had to re-install all the service packs...but it worked out well. IIS is much faster than abyss. We were up to restarting abyss 4 times a day, or more.
    the biggest problems came from redirecting the web directories for our environment. we redirected the default path to /myphone, and redirected the port 5000 to 80. Just a tip, leave 5000 on there, and also bind 80. if you don't the ivr's stop working.
