Copy an existing extension - IN PROGRESS
Discussion in 'Ideas' started by 3CX-IDEAS, Sep 28, 2015.
Copy an existing extension - IN PROGRESS 5 5 43votes
5/5, 43 votes
  1. 3CX-IDEAS
    Sep 28, 2015
    10
    17
    Ability to be able to copy an existing extension and then be prompted to enter new extension number and the provisioning information if required
  2. AlexanderHanna
    Oct 2, 2015
    79
    10
    Re: Copy an existing extension
    This is one that I would love to see. Call it "Clone Extension". Many times you have the perfect setup for an extension and need to create others. The import option only works great if it is a new setup. When you are on a client's site and need to create an extension for a new user, the "Clone Extension" option would be an awesome addition.
    dezmocom likes this.
  3. AlexHeylin
    Nov 30, 2015
    44
    9
    Re: Copy an existing extension - IN CONSIDERATION
    Yes please. Needed to do this recently. Ended up writing down all the BLFs, then selecting all the extns I wanted to set and re-entering the BLFs. Worked, but was a bit clunky and wouldn't scale well.
  4. telin
    Jul 28, 2015
    54
    5
    Let's get it to the top
  5. Chib@voip
    Feb 25, 2016
    21
    This!
    Configure 1 extension with all the important details, have an option to duplicate this X amount of times. If you want to make 10 other extensions, autogenerate 10 new extensions. (and keep all the settings except account ID/extenion nr/passwords. )
  6. mcbsys
    mcbsys New Member
    Oct 8, 2008
    171
    14
    New employee today. Needs a phone with all settings matching an existing employee. Opening two browser windows so I can manually copy all the settings. Sure would be nice to have a Clone button then just fill in extension number, name, email, and PIN.
    Maksim Shvedov likes this.
  7. phoneMonkey
    Aug 23, 2017
  8. Gav
    Gav
    Oct 3, 2017
    34
    Me too!
  9. vizualpro
    Jul 9, 2016
    81
    13
    Can't wait to see this one implemented!
  10. ConnectworksNL
    Mar 2, 2017
    50
    12
  11. it122
    Nov 12, 2012
    Would love this functionality.
    Or copy from one extensions settings to another.
  12. dredd0606
    Feb 14, 2018
    40
    9
    This is still very relevant. I will be deploying a 27 set system this week, and 20 of those sets are to have 24 identical BLFs. Would be much easier to clone one extension 26 times.
  13. Everton Gomes
    Jul 20, 2017
    7
  14. Yury Rabinovich
    Apr 13, 2017
    9
    Yes, this is needed, but for a new setup, for BLFs, you can edit multiple extensions at the same time and set the BLFs for all of them in one go. That's what we've been doing. Import extensions, then edit multiple extensions at the same time to set options/blfs.
    dredd0606 likes this.
  15. dredd0606
    Feb 14, 2018
    40
    9
    I just did this exact thing, but with existing extensions where it was easier to remove the extensions, re-import them (to start clean), and then multi-select in the extensions tab and edit them in bulk.
  16. Tony Cave
    Jun 8, 2017
    25
    +1 this would be great to copy Codec, rights and option settings across to new handsets
  17. Shawn
    Feb 2, 2017
    95
    one up this
  18. ConnectworksNL
    Mar 2, 2017
    50
    12
    Please add this function, saves us so much time!
  19. Christian Hoechst
    Apr 4, 2018
    14
  20. Christian Hoechst
    Apr 4, 2018
    14
