Copy flow to other project
Discussion in 'CRM / Helpdesk / App Integration' started by millsey, Nov 8, 2016.
  1. millsey
    millsey New Member
    Dec 21, 2011
    203
    Hi All,
    Is there a way to copy/move a flow between projects please? I am using VAD 14.0.4141.0 .
    Thanks!
    Millsey
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,598
    125
    Hi Millsey,
    Yes, you can select all the components from a callflow, copy them and then paste them to another project. Or you can copy the file using Windows Explorer, and then "add existing callflow" to the new project, selecting the copied file.
    Kind regards.
