Copying values from the debugger
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, May 3, 2011.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    In the debugger, it'd be great to be able to copy values from the fields. Much nicer for troubleshooting.
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    Yes, that is a useful feature, we'll add it to the TODO list.
