Core services and web login: HELP!!
Discussion in '3CX Phone System - General' started by jiranz1, Jun 12, 2009.
  1. jiranz1
    May 12, 2009
    Hi, I've read through a lot of posts trying to solve my problem with no success.
    I've run 3CX successfully on an XP Pro desktop, then a Vista Home Premium Laptop for testing. Finally installed it on a Vista Ultimate x64 machine for commercial application thinking it would be as straight forward as the testing scenarios. However, core services failed to start (3CX assistant service) and the web interface (both versions) also failes quoting an internal server error - Line: 127 not showing the correct values.
    I've checked the event log which has the following information: Can anyone tell me what to do to get it working otherwise I'm going to tell this guy to get another computer!
    "TLOSS error
    SING error
    DOMAIN error
    R6029
    - This application cannot run using the active version of the Microsoft .NET Runtime
    Please contact the application's support team for more information.
    R6028
    - unable to initialize heap
    R6027
    - not enough space for lowio initialization
    R6026
    - not enough space for stdio initialization
    R6025
    - pure virtual function call
    R6024
    - not enough space for _onexit/atexit table
    R6019
    - unable to open console device
    R6018
    - unexpected heap error
    R6017
    - unexpected multithread lock error
    R6016
    - not enough space for thread data
    This application has requested the Runtime to terminate it in an unusual way.
    R6009
    - not enough space for environment
    R6008
    - not enough space for arguments
    R6002
    - floating point not loaded
    Microsoft Visual C++ Runtime Library
    Runtime Error!
    Program: ... <program name unknown> Program: A buffer overrun has been detected which has corrupted the program's
    internal state. The program cannot safely continue execution and must
    now be terminated.
    Buffer overrun detected! A security error of unknown cause has been detected which has
    corrupted the program's internal state. The program cannot safely
    continue execution and must now be terminated.
    Unknown security failure detected!"
    Thanks in advance.
  2. Discovery Technology
    Apr 19, 2008
    278
    Did you switch off UAC on the Vista machine and set yourself up as a local administrator prior to running the install?
    Do you have any A/V running?
    Also, do you have the latest .Net updates on the system?
  3. jiranz1
    May 12, 2009
    I switched off UAC after the install.
    There is no A/V running. The 3CX is the first installed program on a new Vista install.
    .Net 3 installed with Vista. I tried to update to .Net 3.5 but it took forever and then failed. However I was sure .Net 3 included .Net 2 which is the min requirement for 3CX.
  4. netdynamic
    Jun 13, 2009
    7
    Heh on 3 seperate machines version 3.5 will not install for me either. But it isnt necessary.
