leejor said:It's for 3CX phone devices, so, you would have to be using, say, the Windows version locally (or remotely) to test. Does presence work , on the Android device, when on the same LAN? If not, then the ports to be used for this feature may not match at each end, or there is a firewall issue on the server that is blocking the ports.
leejor said:So...other devices, on the same network, work just fine? it's just this one PC that is having issues? If that is the case, then i would say that there is something on that computer that is causing the issue. I would first try an uninstall, then a re-install. You might also check firewall settings along with what other programmes are running in the background (something NOT running on the other PC's).
NickD_3CX said:A similar problem was discussed here: http://www.3cx.com/forums/viewtopic.php?f=34&t=43819
TSlocum said:All the parameters, starting with "<MyPhoneServerPublicSSLAddr>." are correct. I've also tried it with and without the firewall enabled on multiple machines.
I also opened the config file in a text editor and confirmed the parameters.
Check your inbox!
We’ve sent you an email. Click on the button in the email body to verify your email address – (if you can not find it, check your spam folder).
Upon verification you will be directed to the 3CX setup wizard.
