Could not register to voipbuster. Please help ...
Discussion in '3CX Phone System - General' started by Oli, Nov 22, 2006.
  1. Oli
    Oli
    Nov 8, 2006
    5
    Can anyone give the parameters to put in voip line config for voipbuster.
    Also, The config need a line number. Which number has to put in this field as VoipBuster doesn't give inbount number anymore
    Thanks for a as complete as possible list of parameters.
    Actually, info in voip lines for voipbuster are :
    provider : voipbuster
    Proxy : sip.voipbuster.com
    proxy port : 5060
    registrar : sip.voipbuster.com
    registrar port : 5060
    time between registration attemps : 3600
    stun server : stun.voipbuster.com
    stun port : 3478.
    For the line config, values are :
    line number : (any number, as VoipBuster doesn't give number anymore)
    internal number : 10000, allow in and out on line
    authentication : username and password for voipbuster
    (By the way, in the first screnn for enterring the username, it could not be possible to enter the complete name as the length is too short in the box.
    It has to be completed in the edit screen.)
    Could anyone say what's wrong as I could not find.
    I see nothing wrong in the server status login page.
    The line status always has a red icon for this voipbuster line.
    Please help
    Oli
