Couple problems with Cisco 7941 an 3CX
Discussion in '3CX Phone System - General' started by Aldwin, Oct 11, 2017.
  1. Aldwin
    Oct 11, 2017
    I'm really completely new to the software, and just a little watching how everything works. After a few days of installation. I finally got the system working. I only run into a few problems. I added a sip trunk, I can be called on the number. but I can not call. The time and date shown on the display are also incorrect. Can anyone help me with this ??
  2. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Have you done any inbound rules? It needs to know where the calls route to :)
    Aldwin likes this.
  3. Aldwin
    Oct 11, 2017
    THanks,
    But the inbound in not the problem.
    I can call myself and the phone rings. But if i want to call out, lets say to my mobile, then i get a busy sound.
  4. Schrodz
    Schrodz New Member
    Apr 21, 2017
    100
    14
    Do you have a prefix set? so you have to Dial 9. Have you got outbound rules configured
  5. Aldwin
    Oct 11, 2017
    Thanks Schrodz, :)
    I thought I had the rules righto_O .. However, a mistake a number thanks for your help
  6. leejor
    11,086
    325
