CPU Utilizatino
Discussion in '3CX Phone System - General' started by kbrutlag, Jun 24, 2016.
  1. kbrutlag
    Jun 7, 2016
    9
    I've set up a test system (virtual machine) to try 3CX, and it seems to me that the utilization (no users on the system as yet) runs pretty high. The VM has 1 CPU w/4 cores and 8GB RAM, and with the system idle I'm seeing 70 - 85% load.
    Could be correct, but just seems high to me.
    11,282
    360
    It shouldn't be that high. Are you certain that 3CX is the application shown to be using that ?
  3. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    Which process consums so much?
  4. kbrutlag
    Jun 7, 2016
    9
    Re: CPU Utilization
    Grabbed a shapshot with the following listed:
    3CXPO - 13%
    3CXMediaServer - 11%
    VCEHost - 10%
    3CXTunnel - 10%
    3CXCP - 9%
    3CXlvrServer - 8%
    3CXPhoneSystem - 7%
  5. Frank D
    Frank D New Member
    Oct 6, 2014
    215
    6
    This load looks really strange. Most processes should be quite idle, if there are no users. This is not a normal behaviour.
    If you restart some processes or the server, things stay this way?
    Maybe a PCAP could give you some hints of what the server is so busy doing?
    Anybody has some ideas what could be the problem?
  6. NickD_3CX
    NickD_3CX Support Team
    Jun 2, 2014
    1,386
    88
    Let me verse the suggestion, if you stop the 3CX services does the CPU utilization go down?
  7. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    I realize this is an older topic, but just wanted to let you know what my utilization is if that's of any help.
    On a much older server
    Intel Core 2 Q9400 @2.6ghz and only 4GB memory on Win server 2008 r2
    Idle and no calls virtually no cpu usage or about 2%
    Without knowing which actual processes are using that much cpu, I'd have to guess its probably windows trusted installer (windows update) or something else, not 3cx.
