Crackling Sound In Phone
Discussion in '3CX Phone System - General' started by lateralis_m, Oct 18, 2007.
  1. lateralis_m
    Oct 10, 2007
    41
    I am experiencing an issue on my inbound and outbound calls, where there is a crackling sound in all of our phones connected to our phone network. The caller on the other end of the phone does not experience the same sound. The sound if a faint crackling sound and does not interfere with the call, however, it is more of a nuisance.
    Doe anyone have any suggestions or has anyone experienced this issue???
    I have a Grandstream GXW410x with Cisco 7960 phone.
    Please advise...
    Norm
  2. Ryandc
    Aug 13, 2007
    70
    It's the Grandstream.
    Their gateways are terrible, and that's putting it politely.
    Upgrade to the lastest firmware for it, and consider going all-digital or investing in a nicer Gateway.
    -Ryan
  3. lateralis_m
    Oct 10, 2007
    41
    Thank You Ryan,
    Any suggestions regarding a particular brand digital gateway?
    Regards - Norm
  4. Ryandc
    Aug 13, 2007
    70
    Pattons seem to get pretty positive reviews.
    As for us, we dumped PSTN lines completely, ported our numbers to a VOIP provider who gave us direct trunking at $15/line/month. It was a good deal.
  5. LLangston
    Aug 27, 2007
    57
    We switched from the GrandStream 4104 to the AudioCodes MP-114. Straight out of the box it has much better audio quality. We are still tweaking on it to get things such as caller ID to work(still not sure that is in the gateway, may be in the phones, lol). All in all we are much happier with the new set-up with equipment than we were with the GrandStream equipment.
  6. lateralis_m
    Oct 10, 2007
    41
    Thank you all for your replies...
    I've installed an Audio Codes MP-114 and I am still experiencing the same problems.....There is not difference in the sound quality between the Grandstream and AudioCodes installed on our system. There must be a setting somewhere that controls the delay...
    Regards.
    Norm
  7. AldoLinares
    AldoLinares New Member
    Nov 12, 2007
    135
    Its there really any solution or a better gateway that doesnt make that sound, for me it happen when both parties talk at the same time, if a disable echo i get a lot of echo BUT No CRACKLING SOUND.
    Is it for the echo i guess, but theres any solution?
