Crash (segfault) on 3CX v15.5 Build 15.5.6354.2
Discussion in '3CX Phone System - General' started by Kaj, Nov 27, 2017.
  1. Kaj
    Kaj
    Nov 27, 2017
    After what we thought was rigorous testing we put our new 3CX deployment into production use but on the first day it has segfaulted, dropping in-progress calls and needing services restarted.
    I have seen a few threads about the main 3CXPhoneSystem01.service segfaulting although the posts don't seem to contain any resolutions, so I figured I'd post this, and perhaps an admin would like a core dump for further analysis?
    Version: Build 15.5.6354.2
    Platform: Debian 8.9 running on VMware
    Prior Activity: Seemed to be two incoming calls active at the time of the crash
    Syslog:
    Nov 27 11:05:59 3cx kernel: [6438872.495701] 3CXPhoneSystem[20332]: segfault at 1158 ip 00007f94dabdb590 sp 00007f94c6ffc038 error 4 in libresip-1.10.so[7f94daa69000+25a000]
    Nov 27 11:05:59 3cx systemd[1]: 3CXPhoneSystem01.service: main process exited, code=killed, status=11/SEGV
    Nov 27 11:05:59 3cx systemd[1]: Unit 3CXPhoneSystem01.service entered failed state.
    Nov 27 11:08:48 3cx systemd[1]: Stopping 3CX PhoneSystem 01 IVR Server...
    Nov 27 11:08:48 3cx systemd[1]: Stopping 3CX PhoneSystem 01 Queue Manager Server...
    Nov 27 11:08:54 3cx systemd[1]: Starting 3CX PhoneSystem 01 SIP Server...
    Nov 27 11:08:54 3cx systemd[1]: Started 3CX PhoneSystem 01 SIP Server.
    There is a coredump at /var/lib/3cxpbx/core that I could send to an admin together with anything else needed. Let me know.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,340
    533
    Hello @Kaj
    If you have the ability i would recommend opening a ticket with our support department so they can take a look at the files and better determine why the service is crashing. If you do not have an active support perhaps your re-seller can open a ticket for you.
