Crazy Hack to Provision spa50x
Discussion in '3CX Phone System - General' started by DaveSD, Mar 24, 2018.
  1. DaveSD
    Mar 23, 2018
    13
    For whatever the reason, the 3cx web server will not render an http page on win2012r2, the server responds with 403-forbidden. Using https... the 3cx web server renders fine:
    https://xxxx.ca.3cx.us:5001/provisioning/e23fe4rkay7i/2c86d210ebea.xml
    The problem is all the links in the xml document are to the http version so the phone cannot provision; dead links.
    Here is the hack: I took the output from the https provisioning xml for the mac, edited the xml updating http://xxxx.ca.3cx.us:5000... to https://xxxx.ca.3cx.us:5001... then had IIS render the new xml doc with the https referenced xml doc and the phone provisions as expected.
    Is there a way to get the 3cx webserver to gen the xml doc using https://xxxx.ca.3cx.us:5001 instead of http://xxx.ca.3cx.us:5000 -or- get the 3cx webserver to render http...
    Thanks much,
    ~Dave
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    3,474
    239
    Hello @DaveSD
    Please note that the Nginx webserver will not allow http requests that originate from a remote location or if your IP range is not defined in RFC1918 for security reasons. As Cisco phone do not like https links they are only supported for local provisioning with Http.
  3. DaveSD
    Mar 23, 2018
    13
    The solution for this is simple:
    in C:\Program Files\3CX Phone System\Bin\nginx\conf
    edit nginx.conf
    in the section:
    server {
    add_header X-Frame-Options "SAMEORIGIN";
    listen 5000;
    listen [::]:5000;
    server_name zuzu.ca.3cx.us;
    server_tokens off;
    access_log off;
    error_log nul crit;
    allow 192.168.0.0/16;
    allow 172.16.0.0/12;
    allow 10.0.0.0/8;
    allow 127.0.0.1;
    add your static IP's for your IP Addresses
    For our installation, we did not want the phone server inside our local network. The 3cx server has a static IP outside the local network. Agree or now, this is what we thought was best practice.
