Create extensions based on OU in AD
Discussion in '3CX Phone System - General' started by Xiaous, Mar 19, 2014.
  1. Xiaous
    Mar 19, 2014
    I am currently doing a school project that requires me to create extensions for 1000 users. These users are in 4 separate OUs within a windows domain. Is it possible for me to have 3cx pull the user information from the OUs I need without using the csv method?
    Thank you for any and all help.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,560
    301
    Why not use the csv method?
    Write a script to pull ad info into an excel then update the info to save as csv.
