Create Voice Mail need not press # and 0 to save ???
Discussion in '3CX Phone System - General' started by 5qg4, Jul 16, 2007.
  1. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    Any ways or steps to setup voice mail for no need press # to end of message and press 0 to save at 3CX IPPBX?
    Most PBX can save the voice mail without press any keys to confirm. Just need to recode the message then drop the call. The voice mail will be saved.
  2. SY
    SY Well-Known Member
    3CX Support
    Jan 26, 2007
    1,825
    It must work. Just try.
  3. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    SY,
    Thanks. works for me too. I don't why the default menu is # for end message and 0 for save.
    May I know where can found this information at 3CX manual.
    Thanks,
    5
  4. Costas3CX
    Costas3CX New Member
    Jan 23, 2007
    217
    When you close the phone without press anything, it will save the message.
    When you press # then you press 0 , it will save.
    When/if for some reason the line stays open for 2 minutes, the voicemail will stop recording after 2 minutes and save.
    When you press # but you don't press 0 it will not save
    This information is not available in the manual. It is too much detail for the manual at this time.If the need arises, we will include it in the manual.
  5. etm_ltd
    Nov 18, 2006
    69
    Hi Costas,
    I think it will be great to find i somewhere in the manual or onto 3cx website as a tip
    Lionel
  6. SY
    3CX Support
    Jan 26, 2007
    1,825
    You will receive all of your Voice Mail. Where is a problem?
