Create Voicemail Recording from Wav File
Discussion in '3CX Phone System - General' started by stevodevo, Sep 24, 2010.
  1. stevodevo
    Aug 17, 2010
    18
    I have a professionally recorded voicemail greeting that I'd like to use on an extension. The greeting is recorded in a .wav format but I can't work out how to upload that as the greeting. I have done this on Digital Receptionists but can't work out how to get it done on an extension.
  2. mfm
    mfm Active Member
    Mar 4, 2010
    641
    You would have to upload it here but ensure it is at the correct format 16bit mono according to 3CX standards to avoid excessive CPU usage.
    Code:
    %allusersprofile\3CX\Data\Ivr\Voicemail\Extensions
  3. stevodevo
    Aug 17, 2010
    18
    Thanks! What do I call the file?
