Creating a choice of caller ID for outbound calls
Discussion in '3CX Phone System - General' started by Bekka, Jan 26, 2017.
  1. Bekka
    Jan 26, 2017
    5
    Is there any way of allowing a user to have the choice of caller ID they show when making outbound calls to various numbers?
    11,083
    325
    There may have been, but I don't recall seeing an option added in V15 that would allow you to change outgoing caller ID based on either a dial code, or a specific number (range), in the outbound rules. Outbound caller ID has been set per extension.
  3. DSXDATA
    DSXDATA New Member
    Oct 20, 2015
    185
    64
    Have not tried this on V15 yet: in V14, we would leave the extension caller ID blank and then create multiple SIP providers each with a different default callerID / trunk #. We would then create rules for each that are triggered by preceding digits.
