Creating a Digital Receptionist (Auto Attendant)
converged2
I am looking for the best way to create the Digital Receptionist (Auto Attendant). I familiar with the Broadsoft platform where you call in to an extension and record the Auto Attendant. I also have a Bicom server and create the AA by dialing a * code and extension. For 3CX I have left a voicemail and then uploaded it to the Digital Receptionist but was wondering if there is an easier way?
Did you see this?....http://www.3cx.com/blog/docs/localize-promptsets/
Hi, your best using a software application called Audacity and using a good microphone.
Audacity allows you to save the recording in the correct format for 3CX, all you need to do then is upload to 3CX via the Management Console.
Thank you both for your great solutions. I am familiar with Audicity and have used it in the past working with the Broadsoft.
Take Care,
Lou
Get 3CX - Absolutely Free!
3CX
