Creating a new project doesn't really create a new project?
Discussion in 'CRM / Helpdesk / App Integration' started by SWSDEV, Oct 16, 2009.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    Here's something to be aware of.
    I created a new VAD project and selecte an existng one for the name of the project. It then, of course, asked you if I wanted to replace the old project. Well it correctly replaced the .vaproj file, but since the other files and directories were still there then the old project right back up! Only the global settings had changed to the default ones (since the .vadproj file was recreated).
  2. VAD_Support
    VAD_Support Active Member
    Aug 6, 2009
    690
    We'll take a look at this. Thanks.
