credentials for snom http interface
Discussion in '3CX Phone System - General' started by wgt, Dec 24, 2013.
  1. wgt
    wgt
    Jul 17, 2013
    6
    I'm in the process of provisioning phones and tried to access the snom 821 web interface after a phone was provisioned. It was unsuccessful. I've tried the standard passwords, but nothing seems to work. username I'm using is admin. The config file shows the http_user as admin and the password as %%DESKPHONE_PASSWORD%%, which I'm assuming is the Phone Web Page Password that shows in the Extension -> Phone Provisioning -> Snom 821 page.
    Would anyone know what password to use to access the phone's web page?
    Thanks,
    wgt
  2. gschwab
    gschwab New Member
    Mar 21, 2012
    131
    I know on my Yealink phones the password is changed by the system upon provisioning. Log into the 3CX Management Console, click on extensions in the left menu, select the extension in question and click the edit extension tab at the top. now click the phone provisioning tab at the top, about the third box down in the provisioning area should be the phone web page password, click the little rectangle to the right *** it will show the new password.
    I think the default password for some snom units is "0000", also maybe this as a last resort
    http://wiki.snom.com/FAQ/How_can_I_set_the_phone_back_to_admin_mode_or_factory_defaults_respectively
    just a guess tho.
    Merry Christmas!
  3. wgt
    wgt
    Jul 17, 2013
    6
    Thanks. The password finally worked in the web interface. must have been an issue with copy paste, manual entry solved it.
