credit card POS w/ATA adapter
Discussion in '3CX Phone System - General' started by ZenMasta, May 31, 2012.
  1. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    Anyone ever try this? If so what kind of pos do you have and which ata device?
    11,079
    324
    I have serious doubts that this will work unless it is a very low baud rate, 1200/2400 bps. I have a feeling that the default speed is higher than that.
    See.... http://www.3cx.com/forums/patton-m-ata-connecting-to-a-modem-29529.html
  3. donbru01
    donbru01 New Member
    Nov 30, 2011
    134
    Try to se forced only codec G711 ( on ATA ) , delete other possible codec .
    POS work at low speed , normally aren't other problem .
    If you have Trunk with codec g729 and Ata with codec g729 it possible that work using it , and on g729 modem/fax not work .
  4. ZenMasta
    ZenMasta New Member
    Mar 10, 2010
    174
    I figured this would not be a good idea. Thanks :)
