CRM and Assistant 8
Discussion in '3CX Phone System - General' started by aesteve, Oct 7, 2009.
  1. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    are the CRM deactivate in Assistant 8 ?. I upgrade my system today, and all options of the CRM appears in grey. In the tray icon i have the red phone who say me that i have missed calls, but the missed calls option is in grey and i can´t click on it.
    Thanks.
  2. tpinnovations
    tpinnovations Member
    Jul 30, 2009
    296
    Go to file, preferences options tab.
    Check Enable CRM.
  3. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    I haven´t the CRM option in preferences.
    In wich tab is this option. I can´t find it.
    Regards
  4. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,582
    115
    Of course you wont even have this option if you havent selected to install it in the first place. So if that Option is Greyed out it means you have to RE-Install the Assistant WITH the crm.
      File size:
      32.6 KB
      841
  5. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    Hello, i have this option greyed. I tried now to reinstall assitant because i don´t remeber this option in the instalation.
    I will return with my feedback.
    Than you.
  6. aesteve
    aesteve New Member
    Sep 20, 2008
    136
    Aha, ok
    in the installation you must select install the crm. I keep this part in my fist installation.
    Thanks.
