CRM Dynamics 2011 - Click to Call via Command API
Discussion in '3CX Phone System - General' started by ClaytonNZ, Nov 1, 2011.
  1. ClaytonNZ
    Jun 1, 2011
    6
    I have been trying to work on a little JScript query to enable a phone number in the header of a CRM Entity Form to Click to Call (opening call in the 3CX MyPhone). I have very limited programming experience, can anyone help with my code below? Or is this not really possible?
    function calltcx() {
    var phoneField = "header_mag_homephone_d";
    document.getElementById(phoneField).childNodes[0].style.textDecoration = "underline";
    document.getElementById(phoneField).childNodes[0].style.color = "blue";
    document.getElementById(phoneField).childNodes[0].ondblclick = function ()
    var oShell = WScript.CreateObject("WScript.Shell");
    oShell.Run(C:\ProgramData\3CXMyPhone Client Addin\CallNotifier.exe -cmd makecall: phoneField, 1);
    Thanks!
