CRM Integration: Add SuiteCRM
Discussion in 'Ideas' started by certified1, Mar 28, 2018.
  1. certified1
    Jul 29, 2013
    18
    I would like to see an 3cx-sided implementation of SuiteCRM in your telephony integration set.
    As sourceforge is telling me that there are about 250 downloads per week and approx 3250 downloads in 2018 until now you and we should benefit about a well integrated CRM-to-phone System.
