CRM Integration module - Input string error
Discussion in '3CX Phone System - General' started by woodhouse, Mar 31, 2013.
  1. woodhouse
    Mar 31, 2013
    Hi Guys.
    Having problems with implementing the CRM integration module. Downloaded the latest version so it can work with ACT2013 but....
    on an incoming call the number pops up in the little popup but also get an error screen displaying the following...
    3CX CRM INTEGRATION
    An error occured prossing an inbound call from 07871234567
    Input string was not in the correct format
    Cant find any information on this anywhere
  2. woodhouse
    Mar 31, 2013
    The server log is outputting the following...
    1-Mar-2013 21:58:29.389 Leg L:33.2[Extn] is terminated: Cause: 487 Request Terminated/INVITE from 192.168.1.77:5060
    31-Mar-2013 21:58:29.389 [CM503003]: Call(C:33): Call to <sip:10@192.168.1.74:5060> has failed; Cause: 487 Request Terminated/INVITE from 192.168.1.77:5060
    31-Mar-2013 21:58:29.280 [CM503008]: Call(C:33): Call is terminated
    31-Mar-2013 21:58:29.279 Leg L:33.1[Line:10000<<07872123456] is terminated: Cause: CANCEL from 217.10.79.23:5060
    31-Mar-2013 21:58:24.894 [CM503025]: Call(C:33): Calling T:Extn:10@[Dev:sip:10@192.168.1.77:5060] for L:33.1[Line:10000<<07872123456]
    31-Mar-2013 21:58:24.882 [CM503027]: Call(C:33): From: Line:10000<<07872123456 ("07872123456" <sip:07872123456@192.168.1.74:5062>) to T:Extn:10@[Dev:sip:10@192.168.1.77:5060]
    31-Mar-2013 21:58:24.882 [CM503004]: Call(C:33): Route 1: from L:33.1[Line:10000<<07872123456] to T:Extn:10@[Dev:sip:10@192.168.1.77:5060]
    31-Mar-2013 21:58:24.882 [CM505003]: Provider:[sipgate] Device info: Device Not Identified: User Agent not matched; Capabilities:[reinvite, replaces, able-no-sdp, recvonly] UserAgent: [] PBX contact: [sip:1726030@81.156.211.94:5062]
    31-Mar-2013 21:58:24.881 [CM503001]: Call(C:33): Incoming call from Line:10000<<07872123456 to <sip:10@192.168.1.74:5062>
    31-Mar-2013 21:58:24.881 Line limit check: Current # of calls for line Lc:10000(@sipgate[<sip:1726030@sipgate.co.uk:5060>]) is 1; limit is 1
    31-Mar-2013 21:58:24.660 [CM503012]: Inbound office hours rule (unnamed) for 10000 forwards to DN:10
    the call is all being connected but just get the above error and wont conncet to sage CRM.
    Any help is most appreciated.
  3. 3cxtester
    Jun 10, 2011
    9
    I have just configured with Dynamics CRM 2011 and I have the exact same error.
    Tried different phone numbers, tried leaving just 1 entity to search instead of all 3 like Leads,Accounts and Contacts.
    Tried monitoring the traffic with Fiddler but no request is being sent to the CRM, except from when I change any option in the plugin and press OK.
    Anyone that can help about this ? Since it is happening with 2 different CRM's probably it might be a bug on the plugin...
  4. 3cxtester
    Jun 10, 2011
    9
    Ok, I got an update about this. We contacted 3CX and they told us that this is a known issue. They provided us with an updated version of the plugin that worked fine.
    Woodhouse, contact them and they can send the updated plugin to you
