CRM Integration
Discussion in '3CX Phone System - General' started by sohc, Nov 24, 2014.
  1. sohc
    Apr 22, 2009
    24
    Hi all,
    I have followed this guide at http://www.3cx.com/docs/dynamics-crm-integration/
    The client is already working. It fails when I try to import the customizations. It says 'The import file is invalid. XSD validation failed with the following error: '{0}'. The validation failed at: '...{1} <<<<<ERROR LOCATION>>>>> {2}...'."
    I am using 3CX V12 pro and Dynamics CRM 2011.
    TIA
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    646
    Hi there,
    Please open a support ticket in CRM department for this matter.
