CRM Intregration 3CX
Discussion in 'CRM / Helpdesk / App Integration' started by Jelle Botman, Oct 20, 2017.
  1. Jelle Botman
    Oct 20, 2017
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,444
    540
  3. Jelle Botman
    Oct 20, 2017
    Im a noob in creating CRM integration is there a tutorial somewhere where it shows me what to do?
    I have 0% knowledge about this....
  4. Mike Cartwright
    Jun 3, 2017
    26
    Hi, Jelle!
    What kind of CRM are you using? I recommend that you check Tenfold. It is a 3rd party CTI that integrates CRMs with 3CX.
    Tenfold's features include click-to-call, automatic call logging, a screen pop (caller ID), a call analytics dashboard, and more. If you want a tutorial or a demo, Tenfold's experts can definitely assist you.
