CRM Module/Outlook calls with international number format
Discussion in '3CX Phone System - General' started by nicolafarina, Oct 11, 2013.
  1. nicolafarina
    Dec 28, 2012
    8
    Hi all,
    we are trying the new v12 and his new Windows client. After digging a lot, we discovered than we need the CRM module to launch calls from Outlook like Desktop Components of MyPhone in v11.
    Now, we have all contacts numbers in international format like +39 (xxx) xxxxxxxx and CRM module launch wrong calls.
    Any help?
    Thank you.
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    803
    45
    Re: CRM Module/Outlook calls with international number forma
    No. The CRM module launch the calls correct. You have to set-up the e164 Number Processing correctly and can be found in the 3CX Phone System under Settings / Advanced / e164 Number Processing.
  3. mdages
    Mar 3, 2009
    12
    We've the same problems here. The e164 number settings in 3CX Phone System are correct and the same as in V11.
    In Version 11 it works, now in V12 it does not.
    It seems no matter what I put in the e164 Phone system settings, it always dials the same and always it forgot the + sign.
    A number like +4917012345 is dialed as 4917012345. Correct translation would be 004917012345.
    -Markus
  4. complex1
    Jan 25, 2010
    803
    45
    This is very strange.
    If I create a phone number in Outlook as follows
    Country 31 (the Netherlands)
    Area code 20 (Amsterdam)
    Subscriber number 1234567
    And then store this, the number is translated as +31 (20) 1234567
    When I dial this number, 3CX convert it to 0201234567 and this is what I want, because I live in Holland.
    Now I take your number
    Country 49
    Area code 170
    Also store this in Outlook and the number is translated as +49 (170) 12345
    When I dial this number, 3CX convert it to 004917012345 and this is what you want.
    Conclusion: there is nothing wrong with the CRM Module. :)
    BTW: If I enter manually +4917012345 in the 3CXPhone for Windows, 3CX convert it to 004917012345 which is correct.
