CRM order number
Discussion in 'Call Flow Designer' started by Federico Moschini, Feb 2, 2018.
  1. Federico Moschini
    Jan 6, 2017
    28
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,078
    76
    Hello Federico,
    This is something you can do with the 3CX Call Flow Designer.
    Please let us know in case of needing any help with that tool.
    Kind regards.
  3. Federico Moschini
    Jan 6, 2017
    28
    Dear Edosa any step by step to make this with 3CX call flow ? I didn't find a sample like this on your CallFlow manuals.
  4. voiptoys
    voiptoys Member
    Feb 13, 2013
    487
    80
    There are plenty of examples of how to prompt a caller for an account number, but I think ultimately you want to perform a screen pop that brings up the appropriate contact in your CRM based on the account number the customer entered. That's fairly complicated, particularly if you are sending the caller to a queue. In this case, when the agent answers the queue call, it will need to look at the 3CX call ID, and match that to the account number entered by the caller, then pop the URL with the account number as a parameter. This will require both a CFD application, and a CRM plugin. We do this with all our CRM integrations, and much more. If you need help, contact us at https://www.VoIPTools.com.
  5. edossantos
    Jun 27, 2007
    1,078
    76
