CRM Suggestions for 3CX
Discussion in '3CX Phone System - General' started by techmeaux, Apr 18, 2011.
  1. techmeaux
    Apr 18, 2011
    I'm going to begin configuring the 3CX system for a friend, and it's going to be exchanging data with a CRM. He wants to use SugarCRM, but I think it's open to suggestion, so I wonder if anyone can make a suggestion in case someone knows a good system for integration before I leap into one which he has not tested, or used, to save the possible week of switching to another.
    I think customization will be ongoing for various reasons, and that's why I was considering Outlook because of the automation ease.
    I'm a 3CX newbie, but am a developer, so any info would be helpful. Thanks
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    If you are just starting out, then sticking to supported CRM systems would be wise:
    - Outlook 2003, 2007, 2010 (32-bit)
    - MS Dynamics
    - Salesforce
