CTI Button missing ?
Discussion in '3CX Phone System - General' started by Pieter Eijkmans, Jun 24, 2013.
  1. Pieter Eijkmans
    Jun 21, 2013
    I cannot find the CTI Button or it is not working ? On the left on the display I can see CTI but I am not able to switch off CTI.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,545
    298
    I do not think you can turn on/off from the win phone right now. you turn it on by enabling it in the extension in the admin console and then setting up the hard phone.
    The first time you try to use it, I saw a "Request Remote Control" on the phone display and I had to hit accept.
