CTI control over mobile phone
Discussion in 'Ideas' started by tim942, Nov 16, 2015.
  1. tim942
    Jul 30, 2015
    68
    6
    Forgive me for referencing Shoretel, but using communicator to control calls initiated from forward to mobile was a really good work around for poor internet connections when working remotely. Is it possible for this integration into 3CX for Windows, or are the *8X commands the only thing possible?
